Hey all!
Just hought I'd post about my missus' car. The Vectra CDTi 150 SRi is a 56 reg with 127k miles on it now. Have confirmed it is on it's ORIGINAL inlet manifold, as the first (previous) owner never had it changed. About 9 months ago, I found the swirl bar off, and the flaps were stuck solid in the open position, so I left it for then. Leaving the swirl bar in the garage for fix at a later date.
This morning, I used WD40, and a long socket extention to reach down to the valve's and move them rigorously, until they moved freely. Did this with 1, 2, and 4 - the third one moves when the engine is revved, so the motor has not seized. After about 10 mins, all valves moved extremely freely. I re-attached the swirl bar - not that difficult, just fiddley, then started her up.
Result
Much quieter immediatley. After a few revs, it was clear that the bar was moving all valves freely, as it should. Took it for a brisk drive to warm up, then a hard drive. Performance has been transformed and the car drives better than it ever has done. After a quick check, the bar is still attached. If it does fall off, I will do the £1 repair as detailed in this forum. But, after a 20 mile run this morning, all looks good still.
I then cleaned and blanked off the EGR, unfortunately, this threw on the spanner light and the emissions light, so I drilled a 8mm hole in the blank then cleared the fault code. Job done. Lowdown rev performance has greater improved.
Next, I sprayed a whole can of carb cleaner in through the air intake, again, as on this forum. The black smoke was HORRENDOUS while doing this, and EVEN MORE HORRENDOUS when I floored it afterwards to clear it out , I was getting flashed by everyone who passed!!. However, after a 5 mile drive, there's no smoke, and lots more power throughout the rev range, with more pull from about 1500rpm, rather than 2-2.5k rpm.
So, for a morning's work, I may have revived an old manifold. As said, it's done 127k miles, and there is slight play on two of the valve bearings. Going to keep an eye on this, but looks promising.
So if anyone else is thinking of removing the inlet manifold to clean / replace, try this first. Cost me £3 for a can of carb cleaner, everything else was just my own time.
I then reset the BC, and after yet another drive (about 5 miles), the consumption has improved too.
