Results 1 to 10 of 14
Thread: Trim Removal
    Default Trim Removal
    I need to fit a handsfree kit.
    Does anybody know how to remove the A-pillar trim so that I can run the microphone lead? It looks like the curtain airbag might be anchored at the bottom of the A-pillar.
    Regular Member C19_CJB's Avatar
    Beverley, East Yorkshire
    I didn't dare take that trim off just incase I set the airbag off!!
    I ran my wire down the steering column and mounted the mic on the pad between the cluster and the steering wheel
    give leeds vectra a pm hes your man
    Professional Trader
    sheffield
    Just pull the a-piller trim off, its only clipped in, its not attached to the air bag at all..
    As Rich says, it just pulls off. You won't set off any airbags.
    This PDF should help you as well. You may damage a couple of clips when taking it off, these can be easily obtained from Vx.
    HTH
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    You all beat me to it. As above
    PAul.
    Fantastic. Thanks.
    All I do is get my fingers under edge and pull a little then took wire behind with screw driver I have done this with last 3 cars and not taken trim off and you couldn't see any wires
    I've just been scoping out the install.
    I've pulled as hard as I dare, but I can't for the life of me get the A pillar trim off. The flat plastic clip that goes through the trim at the top just won't budge. I could just tuck the cable in between the trim and the door rubber as suggested above, but this would place the wire between me and the airbag. I'll see if I can tuck it in between the windscreen and the trim instead.
    I've also had the radio (CD30) out. Vx have conveniently labelled the pins, and there's even a (mono) audio input. I'm not a fan of Scotchlok connectors so I'll probably just get an aftermarket cable adaptor but there's no ignition switched supply to the radio.
    I dismantled the trim around the cigarette lighter to see if I could tap in there and I noticed that there's a unused wire taped to cigarette lighter connector. Anybody know what that might be?
    Is it safe to put a wire in front of an airbag ? will it not prevent the airbag functioning properly ?
  1. A-Pillar trim removal
    By jammy_c in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2012, 15:26
  2. Help! Hatch Trim Removal
    By wafoo in forum Bodywork & Interior
    Last Post: 16th February 2012, 18:28
  3. Pedal Trim Removal
    By vectrasimonsri in forum Bodywork & Interior
    Last Post: 6th April 2011, 10:42
  4. Dash trim removal - Please help
    By AntSSSS in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2009, 12:57
  5. Trim removal
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2007, 14:45
