Can Someone Please Tell Me How To Remove The Front Bumper, I Hope Its Not As Bad As The Vectra B Was. Many Thanks
Easy. Three torx screws in each wheel arch. Two rivet type things under the bonnet next to each headlight. Then underneath four plunger style plastic rivets. Buy new plastic ones saves time trying to keep them in a decent condition to refit. Then tug it outwards from each wheel arch, then forwards to remove. Watch out for any wiring looms attached before you completley remove.
HTH
Thanks For Your Help, Sounds Much Easier Than I Thought![]()
or you could check ou the HOW TO section![]()
Thanks For Your Help Guys, I'm So Glad You You Lot Are Here To Help
